Alfred.NESWADBA
en respuesta a: Anonymous
please find attached a dwg-file which has the modifications done, the points are moved to a Z-value according to my understanding of the job.
Within the file you'll find:
  • the points moved to Z
  • points and text color changed to green for objects matching together
  • lines in green showing the connection from point to text objects ... for visual control to see which text objects were used for the Z-value of the point (to prevent the wrong text value is found)
  • points and/or text objects in red in case something went wrong (not in that drawing, but build in into code)
I have also attached a VBA file (you'll need to install the AutoCAD Visual Basic Enabler >>>click<<< to load and run the project).
  • You can use command _VBALOAD to load the DVB file
  • You can use command _VBARUN to run the procedure "PntToTxtZ"
Please take care, this tool is written without error handling and without warranty that it does what you expect. So please save before running the code and verify the result.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
