- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
YOu can use the command textscr or hit function key F2 to run on or off the text screen.
Select the text you want to copy then use Ctrl C to copy to the clipboard and then Ctrl V to paste it into your response.
I assume you are clicking point #1 when you are prompted for the first point and not typing a t. Only enter the t when you see an option for it. For example, the prompt may look like this:
Enter next point or [end Tangency/toLerance/Undo/Close]:
at this stage of the command you have 5 options
1. enter next point
2. T
3. L
4. U
5.C
If you see the prompt Enter next point or [end Tangency/toLerance/Undo/Close] is it at this stage you would enter the T (or t).
If you do not see "end Tangency" then that option was not available in 2014 and you should edit the control vertex polygon
