10-25-2019
07:55 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
10-25-2019
07:55 AM
AUtoCAD 2004 is pretty old. The spline command back then may not have had the tangent option.
If not you can get the spline to be tangent by manipulating its Control Vertex polygon as I noted at the end of post #4.
Open the properties dialog box and select the spline. Do you see a Method parameter? If so, change it from Fit to Control Vertices then move the 2nd CV to a point on a line that is the continuation of your original line.
lee.minardi
