Alfred.NESWADBA
en respuesta a: Anonymous
>> In contextual/realistic view, zooming in to look at close
>> detail causes the screen to go black
If the screen changes to black then you have a graphic card memory issue (most probably hardware, with minor chance a software/driver issue) ... the reason for that: If it would depend on the geometry of AutoCAD only the drawing area would get black, not the whole screen.
>> Every .dwg file opened (first time or multiple times)
>> throw error about file being "read-only"
Where are your files stored?
When you create a local folder, e.g. C:\ACADDWG and give that folder ALL permissions, turn off antivirus, can you then save a dwg-file into that folder and open it without readonly? If that works, it's not an AutoCAD issue, you might have permission issues on your network, on your drive you are saving to or with your antivirus.
I don't say AutoCAD is free of errors and that it never crashes ... I just want to show you that also other sources can exist for your issues!
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
