en respuesta a: jggerth
HiJGerth:
I tried your suggestion and the command opened a "1 or 0" box which I tried both (it opened as a 1) but does not seem to affect the problem in any way.   I could try to attach the drawing but this issue seems to expand the file size exponentially for each annotative block contained inside the drawing.
When I try to delete any of the text on the screen (UNICODE or STANDARD) it deletes the block (wire frame text everything) that went with that block.   I should note that this OLD drawing was created by someone several years ago, I find this method of annotative attributes rather slow and cumbersome to work with.
thanks for help so far
Mark
