10-24-2019
05:04 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
10-24-2019
05:04 PM
I copied and pasted your dialogue to my reply and then I added what I see, in dark blue, after after what you saw.This is what you should've seen.
After I enter the spline command:
Current settings: Method=Fit Knots=Chord - I don't see this. All I see is enter first point Specify first point or [Method/Knots/Object]:I don't see this following enter first point. Enter next point or [start Tangency/toLerance]: t space - I don't see this after I Enter the first point. Specify start tangent: click point to define direction of tangent - If I enter the T and hit the space Bar, all I see is invalid point followed by enter next point. Enter next point or [start Tangency/toLerance]: point #2 Enter next point or [ Tangency/toLerance/Undo]: point #3 Enter next point or [end Tangency/toLerance/Undo/]: t space Specify end tangent: click point on line but below point #3
The notations in blue are what I see (or don't see) when I try to follow the steps you described.
I'm using Autocad Ver 4
