- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
copy to cliboard failed
i am running auto cad 2017. when i try to copy and paste from my dwg files i get an error message "COPY TO CLIPBOARD FAILED. I HAVE CONVERTED PDF FILES AND HAVE PASTED GRAPHICS FROM THE CONVERTED PDF FILE TO MY DWG FILES. ANY ONE KNOW HOW TO WORK AROUND THE INABILITY TO COPY AND PASTE FROM MY DWGS.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
here is (1) of my dwgs that i recieve the copy to clipboard failed message
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
HI
in my site no error.
Check this file ,its a new file includes all objects copied from your file.
Maybe you don't have enough memory(ram).
try unload the residence unnecessary windows app.
but first try on this file.
good luck
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi Ara, Thx for the reply. After opng the drawing 5 you sent back, it seemed is a block. I would have to explode this first , before i could trying to copy and paste any items. My computer has 16GB of ram. i am not familiar with unloading the residence unnecessary windows app. Could you explain this to me.
thx dennysbyhp@aol.com
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Not that it will make you feel any better, but I also had no problems copying to the clipboard the entire contents of your dwg file.
A few suggestions.
Option 1. Try narrowing down what you are copying to the clip board. try smaller sections until you find the area that is causing the issue, then something might be apparent.
Option 2. Use the WBLOCK command to Write out what you want from this file and then use the insert command to insert the block into the destination drawing, at that point you can explode or leave as a block.
Good luck,
