tramber
en respuesta a: Anonymous
Maybe you can use the _DIMORDINATE that gives a X or a Y from the 0,0 point.
Maybe, if your object is a block, you can use the _FIELD command on an object and obtain its X or/and Y of its insertion point from the object category....
I must say that I don't know exactly what you want... but it is surely possible :cara_que_ríe_con_la_boca_abierta_y_los_ojos_sonrientes:
