10-23-2019
02:33 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
10-23-2019
02:33 PM
Autodesk listens only over here https://www.autodesk.com/company/contact-us/product-feedback
What is the make/model of your laptop?
In the meantime, ensure you have the 2020.1 update (ABOUT command will confirm) and if needed.
DWGs tagged as read-only is a system level flag, not fixable from inside AutoCAD: if you have to tap the same button twice that might also mean your file is still busy "doing something".
3D Orbiting jumpy is a video card issue: as a test, only a test, turn off hardware acceleration and see if that helps or makes it worse.
HTH
HTH
