900 Vistas, 5 Respuestas
AutoDesk LISTEN TO YOUR USERS - FIX ACAD!
THIS IS AN ATTEMPT TO GET THE ATTENTION OF AUTODESK PROGRAMMERS -
I am a user of Autodesk products for 10 years - I know the in's and out's of the program. The problems below are not new and yet there have been no solutions provided to users. I have googled and read the majority of previously offered "solutions" so NO those don't work.
AutoCAD 2020 version; PC laptop with hardwired internet and additional screen connections (no, going to the 1 screen does not fix this); graphics card = NVIDIA GeForce GTX 1080 (it's up to date); I have full control permissions on the whole computer.
In contextual/realistic view, zooming in to look at close detail causes the screen to go black - audit, purge, recover, regen, regen3, regenmode, lens length, hardware accelerator, linefading, linesmoothing, etc. do nothing to resolve this problem.
Every .dwg file opened (first time or multiple times) throw error about file being "read-only" when trying to "save", have to select "save" twice to actually save file - properties of parent folder and underlying files set to not be "read-only" through dialog box and command prompt - does not fix problem.
3D orbiting while using the "shift+mmb" is very jumpy and flickers across screen - regen and other options above do not fix this problem.
Acad randomly crashes multiple times a day.
These are the same problems that MANY people have had with previous versions that Autodesk STILL HAS YET TO FIX. I can't do my job if the program is faulty.
