348 Vistas, 2 Respuestas
10-23-2019
01:49 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
10-23-2019
01:49 AM
commands are not taking properly
hi, i have a issue regarding the commands when i enter the command as L it is not taking the line command it is taking to last angle and in some cases it is showing invalid command , plz help me out of this .
10-23-2019
02:29 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
10-23-2019
02:29 AM
Looks like the program parameter file(.pgp) has been messed up. Try resetting the AutoCAD to defaults. Here is how you can do that : Click here
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
10-23-2019
03:19 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
10-23-2019
03:19 PM
Hi
try to type full command name. or use menu bar
if with full command name or menu bar everything is ok ,then
1- you must check "aliasedit" or pgp file. with menu Tools/customize/edit program parameters (acad .pgp)
good luck
