604 Vistas, 5 Respuestas
need help about convert mesh to solid
Hello. i have a mesh object. and i need to convert it solid. but when i try to convert it i see this error "Mesh not converted because it is not closed or it self-intersects.
Object cannot be converted." . is there anyway to convert it? thanks
file is
JDMather
en respuesta a: Anonymous
I would use the attached solid only for reference in creating proper geometry.
en respuesta a: JDMather
Thanks for your help but that is not what i want. I want to convert that mesh to completely solid. and i think that is not possible
JDMather
@Anonymous wrote:
... i think that is not possible
The file I attached is completely solid.
How much training and experience do you have?
If  you check the Properties or List of the file I attached - what does it say?
Yes it is 3D solid. but not like as i want. i dont know how to explain what i want. i want it to be like i draw it again. i will tell you everything. i converted that dwg file from an .stl file. and i want that drawing to be like as i draw it. My english is finished. :cara_con_una_leve_sonrisa: Thanks :cara_con_una_leve_sonrisa:
JDMather
In other words - start over and model if from scratch.
stl files are of little use other than for 3D printing.
