680 Vistas, 5 Respuestas
AUTOCAD Recommendation
Hello All,
We have bought 2 equipment Atom Knife cutter and DMH -ST10 CNC.
We are looking for CAD software which can integrate well with both. Does anyone has worked on above machines. Your input is much appreciated.
Thank You
Lokesh
Tomislav.Golubovic
en respuesta a: Anonymous
What kind of work do you do?
en respuesta a: Tomislav.Golubovic
mfg gaskets mostly foam and paper
Tomislav.Golubovic
Autodesk has a product called CAMduct which will nest files onto "Sheets" and then send that information to the cutter. If you can get a DXF out of whatever product you're drawing the gaskets in, you can nest them all within CAMduct.
The other one might be Fusion 360 or Inventor, where you can 'draw' the gasket and then send it to the machine.
Thank You . Do you know email contact for AutoCAD so that I Can contact them and request for DEMO.
Lokesh
Tomislav.Golubovic
The company is Autodesk. You can look on their website for a reseller near you so they can demo it
https://www.autodesk.com/partners/overview
