pendean
en respuesta a: vandenoosterkamp
You wrote (and everyone else missed):
>>>...I mainly seems to happen with drawings that have had pointclouds inserted into them, via cloudWorx...<<<
That's just the nature of working with pointclouds: there is not a PC fast enough on the planet to help.
BUT... you are using a 4-year old version of AutoCAD too, at this point you probably should be using AutoCAD2020 (works a bit faster with pointclouds) if you want help from Autodesk and most end users around these forums.
HTH
