jamesmac1201
en respuesta a: Anonymous
Well this methodology applies to any earlier version being saved to a newer version (i.e. 2007>2010; 2010>2013; 2013>2018). If your drawing contains only 2D/3D linework, then I recommend performing an Export operation if the drawing was already saved to 2020. I use Civil 3D, so those special entities need to be converted before I send to a client that doesn't use (or have) Civil 3D. If you haven't saved the drawing after you made your changes, you can perform a save as, then select "Files of type", then choose the 2013 version.
