2286 Vistas, 7 Respuestas
How can I move dimension lines?
I need to make the dimensions vertically (like the red arrow shows it) and whenever I select the "aligned" dimension it does the same thing like the linear one (green arrow).
Alfred.NESWADBA
en respuesta a: Anonymous
You need then to set the UCS to the plane you want to have the dimension drawn on (take care that dynamic UCS is not active) ... then create the dimension.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
en respuesta a: Alfred.NESWADBA
I have UCS on, still nothing.
Alfred.NESWADBA
>> I have UCS on,
Can you please upload the dwg-file?
- alfred -
Alfred NESWADBA
ara_neresesian
Hi
use dimedit. Oblicue  and make it aligns to the vertical line.
good luck
Alfred.NESWADBA
>> I have UCS on
"ON" does not help, it needs to be defined to the plane you want to have the dimension on...
- alfred -
Alfred NESWADBA
late at night I managed to find a video that solved my problem - https://youtu.be/6reJsWxvGyM?t=396
We haven't come to 3D drawing yet, but thanks for taking your time and making a video!
en respuesta a: ara_neresesian
Hello, I've already found out about this but I will mark it for others to see, thanks :cara_que_ríe_con_la_boca_abierta_y_los_ojos_sonrientes:
