RobDraw
en respuesta a: Anonymous
@Anonymous wrote:
I feel somehow that it's related to an OS update???
If it were, there would be more posts about it. Have you restarted the computer since your issue started?
Your settings look correct as long as you are using OSnap Tracking. If that got turned on accidently and you are unfamiliar with using it, it can get in the way of OSnaps working as expected.
If that is on purposely, you are going to have to explain your issue more clearly. You started off saying that they aren't working and later said they seem to be working partially.
A screen cast showing the behavior would be extremely helpful.
Rob
