408 Vistas, 5 Respuestas
CAD drawing to PDF problem
Hello
Ive attached a picture of a hatch which solid. The horizontal lines only appear when  I convert the drawing to a PDF. Do you have a solutionhatch pdf.jpg
Do yo
Alfred.NESWADBA
en respuesta a: Anonymous
if you are using Adobe Reader then first check the settings mentioned in this post >>>click<<<.
If that does not help then please
  • let us know which version of AutoCAD you are using (command _ABOUT shows the details)
  • which driver you used to create the PDF
  • upload the dwg-file so we can test with that file on our systems.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
en respuesta a: Alfred.NESWADBA
Hello Alfred
Im using Adobe Reader but I cant access the link in your message
Tess
Alfred.NESWADBA
sorry, my mistake. Here's the link corrected: >>>click<<<
- alfred -
Alfred NESWADBA
Hi Alfred
Ive looked at the PDF setting & they are the same as the ones in the link, should I change tick  untick some boxes
Tess
Alfred.NESWADBA
can you please
  • upload the dwg-file you try to create a PDF from
  • the PDF file that has these issues
  • start command _ABOUT and show us a screenshot of that dialog so we know which version of AutoCAD exactly you have.
- alfred -
Alfred NESWADBA
