rkmcswain
en respuesta a: tomcarver
If you happen to paste or import something into your drawing that is not at the 0.0 elevation, and then you use Object Snap on these entities when creating or modifying other geometry, you can cause the created or edited objects to move to the non-zero elevation.
You can set OSNAPZ to 1 in your drawings when you're working to avoid this.
