BeKirra
en respuesta a: Felix_I
I have no problem with this command with AutoCAD 2019.
I don't think the removing PAT files causes it.
Will a restart solve the problem?
Otherwise try to reinstall.
HTH
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
