- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
QuickCalc not working on neither ACAD 2018 or 2019. I receive the error message "CVUNIT failed to convert units." I tried all, Volume, Length, Areas.... same thing, it wont convert anything. I read it may have something to with the file acad.und but I have that file on both versions. This happened after I cleaned some old hatches from the SUPPORT ( .PAT files)
any ideas?
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I have no problem with this command with AutoCAD 2019.
I don't think the removing PAT files causes it.
Will a restart solve the problem?
Otherwise try to reinstall.
HTH
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
restart will not fix the error. I try not to reinstall, time consuming. I thought someone might know a quick fix.
thanks.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Yes reinstall can be time consuming. Instead try resetting the AutoCAD to default. Here is how you can do that: click here
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Good info.
Would that affect my Workspace settings? I wouldnt want to lose my ribbons.
Thank you
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
it worked great.
I was afraid I would lose my settings and I did a backup first but it proved to be unnecessary as the reset tool will prompt you to save the settings in a .zip file on your PC! very intelligent!
Thanks for the hint!
