- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hello people,
I am trying to efficiently highlight a Layer or multiple Layers for quick visualizations purposes.
What I want is to isolate the objects of a Layer in a special way that allows me to see them where they are amidst the huge information I have in the drawing.
The only solution I have (and bear in mind, this solution is very tiring and time wasting), is to select all layers, change their color to dark grey, and then change the color of the desired layer to a bright color like yellow. Then I have to undo all or it might mess up my drawing. But this doesn't always work because some objects don't have the "Color by Layer" property, so I have to manually change its color.
Another solution is to isolate the Layer, but when I isolate the Layer I can't see the rest of the drawing so it's not that useful.
But maybe there is a Lisp command that allows to quickly highlight the objects of a layer, or any object wanted, similarly to how the Quick Select command works, but instead of selecting objects, it would highlight them from other ones, like with a bright color contrasted with a dark unsaturated color. It would be sooooo useful.
Thank you
¡Resuelto! Ir a solución.
