10-03-2019
08:54 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
10-03-2019
08:54 PM
In Inventor 2020
I'm assuming you are exporting a flat pattern or flat shape? it is so simply to do this.
Left click on the face you want to export as dxf, when highlighted right click and select
"Export face as" you'll get the file name prompt but don't save it yet... go to Options ( to the left of Save )
then select file version you want to save as you can go all the way back to version R12, make sure the 2 boxes
Pack and Go & Customize DWG/DXF are unticked.... select Next then make sure Data Scaling box is set to
Base View Scale - Model Space then Finish ( you can also save configuration if you want
Hope this helps
