10-03-2019
03:10 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
10-03-2019
03:10 PM
Thank you for the screenshots! I can reproduce the issue, with 2019 as well as with 2020.
When having dynamic input on you get at least a dimension like object that shows the correct angle. Having dynamic input off means you only see one result in the command-line and that shows 0° ... which is not correct.
At least ... 2014 tested, same issue.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Alfred NESWADBA
