Alfred.NESWADBA
en respuesta a: jeff.lentz
>> subsequent measurements of 90 degree angles report the results
>> as "0 degrees" in both the hovering menu and in the command line.
Can you please show a screenshot of that? I have no idea what "subsequent measurements" are and when an angle is shown in the command-line.
For me a measurement of an angle means the angle between 2 objects, and therefor the setting of 0° to north does not influence that. The only situation changing the 0° direction I see is to construct objects, so to enter relative coordinates from a startpoint with a direction and length (for a line), then the direction can be use with 0° to get a line in direction to north. But for measurements ...?
That is what I see while creating a line with 0° set to north, working well for me, if that is your issue:
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
