jeff.lentz
696 Vistas, 8 Respuestas
Non-standard Drawing Units Angle Settings Break Angle Measurement
When I set Drawing Units, Direction Control to "North" so 0 degrees will be at the top, subsequent measurements of 90 degree angles report the results as "0 degrees" in both the hovering menu and in the command line. Only the floating measurement within the angle itself correctly reports the angle as 90 degrees.
