565 Vistas, 12 Respuestas
changes from 2015 to 2017 or 2018 for referenced files
A drawing file created in autocad2015 had embedded images. It opened and plotted with no problem- everything showed up. Now we are using 2017 and 2018 (2 different people) and when opening the drawing it says it can't find the referenced files. If you choose "ignore unresolved files" the drawing opens and all embedded objects are visible. When you go to print, they do not. Did these later versions of autocad change some variable?
Thanks in advance,
Sylvia
