DRoam
en respuesta a: cadffm
@cadffm wrote:
1. dxf2019 is impossible, dxf2018 is the newest (ACAD2018/2019/2020/?)
2. "I have a tool..."
    Then you should edit this tool if it's your own, or change the setup for another file-format, if it is a third part program.
(Is your program? API? Code? ..)
My mistake, you're correct, it's exporting in 2018 DXF, not 2019.
It is via the API. And the only way (as far as I'm aware) to export specific faces via the API in Inventor is by executing the "GeomToDXFCommand" command definition, which does not accept any arguments (except file name, by posting as a private event before executing).
If you know of another way to export faces or control export version, please do share it in the other thread I created in the Inventor forum: Inventor Forum: API "Export Face As DXF" in previous version?
Thanks.
