ara_neresesian
en respuesta a: Anonymous
Hi
its very easy for line if you can explode them temporary to line calculate the numbers and then undo its
1-you can do by autolisp
2- quick select
by the way this is a sample for line , using an auto lisp will be very easy , with small lisp you will have a report from all lines
if you need to use this routine every time ,its more better to load a lisp file.
just attache one small sample of your jobs includes the results , (just to see what layer shod be calculate  ... )i will write a lisp file to help you.
good luck
