Alfred.NESWADBA
en respuesta a: Anonymous
you should have used blocks with scaling.
Using polylines means you need to write a tool that identifies the order of the polyline vertices, then the distances and angles between these vertices and see if that is now horizontal or vertical.
Use a block, best would be 2 different names so you can later use the block names to identify this is a vertical or this is a horizontal one. Scaling of the block then shows the length of the frame ... and using command _DATAEXTRACTION to get your list, without any coding.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
