09-27-2019
02:51 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
09-27-2019
02:51 PM
Yes it is possible. If you know how to create a Block, then you can do it using Super Hatch command.
Create or draw your hatch pattern. Then turn it into a block. Next, use Super Hatch command, found on the Express Tools Ribbon. It will 'tile' your block to fill up your area. Put some thought into how you draw your hatch and how you turn your hatch into a block. If you don't, your Super Hatch won't tile nicely. If you need to scale or rotate your hatch, keep your eye on the command line, there are scale and rotate options built into the command.
Screencast:
Chicagolooper
