Alfred.NESWADBA
en respuesta a: peeveen
you should not kill a process, instead create an AutoCAD script, that e.g. draws a line and then use command _QUIT to exit AutoCAD in a normal way (and watch the event to continue when the acad.exe process ended). Killing a process like AutoCAD that uses a lot of sub-tasks (e.g. licensing check) might leave one or the other task open.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
