cadffm
en respuesta a: Anonymous
@Anonymous  :cara_durmiendo:
I posted the PDFATTACHMENT to CAD-Objects solution (not signed as solution at this time.. )
The next one: Raster-data from PDF to imagefiles.
If you used my little program your PDF ATTACHMENTs already exists, then run the Tool again after setting the wanted variable-values.
http://help.autodesk.com/view/ACD/2020/ENU/?guid=GUID-D72E9CE9-CC0B-472E-BBD5-AB3DA054D777
for your new raster images
PDFIMPORTIMAGEPATH
for ONLY raster images:
Set PDFIMPORTFILTER to 7 and run the tool again (after you reload the pdf-attachments first, command XREF)
or delete all and set PDFIMPORTFILTER to 0 and run the tool again (after you reload the pdf-attachments first, command XREF)
Sebastian
