vinodkl
en respuesta a: Anonymous
When you import PDF into drawing using "PDFIMPORT" make sure you check mark the option "Raster Image" which would also import the raster image into the drawing.
But this would xref the image into the drawing, so when you sending this drawing to someone you need to "ETRASMIT"  so  that the image would be included with the drawing(images will be saved in the location where PDF is located inside a folder named  "PDF images")
If you want the images to be embedded into the drawing and open the images from the location described above in windows paint and select all (Ctrl+A) and copy (ctrl+C)  and open the drawing and type in the command "PASTESPEC" and select paint brush picture and click on ok. Doing so would embed the image into the drawing and there is no need to etransmit.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Etiquetas (3)
