- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
One of my colleagues has asked me to convert a 44 page PDF document which contains text and wiring diagrams into .dwg so that we can send to contractors for them to edit the wiring diagrams for specific jobs when required.
I imported all 44 pages into the model space and then created a paper tab for each page and used a view port for each page. I have saved as .dwg but it still requires the PDF to be present in the same folder location as the .dwg, it's not a big issue just adds a bit of complication for the contractor. But i thought when you import a PDF it would create it as its own separate entity? Is there a way to link the PDF to the .dwg so that its always attached when transferring and moving around?
¡Resuelto! Ir a solución.
