pietro.pedone
en respuesta a: Anonymous
Hello @Anonymous ! When you set DRAWORDERCTL to 0, you're only influencing the behavior of new or edited objects. The Help says that the value 0 "Turns off the default draw order of overlapping objects: after objects are edited, regardless of their draw order, the objects are displayed on top until a drawing is regenerated (REGEN) or reopened. This setting also turns off draw order inheritance: new objects that are created from another object using the commands listed below are not assigned the draw order of the original object. Use this setting to improve the speed of editing operations in large drawings. The commands that are affected by inheritance are BREAK, FILLET, HATCH, HATCHEDIT, EXPLODE, TRIM, JOIN, PEDIT, and OFFSET."
There currently is no way to "clear" draw order for all objects, specifically because there is no "default" draw order--but rather the one specified during the creation of the objects. I'd suggest that you either delete all wipeouts (as @pendean suggested) or select all objects that need to be moved above other object and move them.
Hope this helps you! If it does, please mark my answer as Solution :cara_con_una_leve_sonrisa:
Pietro.P
Global Product Support
Autodesk Knowledge Network
