dbroad
en respuesta a: Anonymous
FYI, you can create a shape from linework with Express Tools command MKSHP and can make a linetype with the MKLTYPE command.  No need to have someone do it for you.  The challenges to such a method would be to maintain the overlap (approximatly 1/3 or 1/2).  Curved, especially reverse curved and sharply curved patterns will give you the most problems. Simple circular curves are most critical at smaller radii but each offset makes the curves longer so end trimming will be required.  Then you could block the results and crop them to form the appearance of a hatch.
Also, avoid full hatching kilometers of pathways.  Hatch is for details.
Architect, Registered NC, VA, SC, & GA.
