Alfred.NESWADBA
en respuesta a: Anonymous
>> Then I should be able to scale it.
No, that is not the real solution as the STL is already a triangulated file format, scaling means then you scale the triangles, the segmentation can't be modified.
So if you want to get a cylinder, which size do you need?
However, if you have a software that can scale cylinders, then you can also create cylinders, can't you?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
