09-20-2019
02:06 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
09-20-2019
02:06 AM
>> .stl is what im exporting to.
So you need 3D-Solids as objects, block-insertions can't be exported using command _EXPORT to format .STL.
Instead of discussing 7 days in the meantime ... why not scaling your block like you need it (to have all object snap points) and create the object with the existing block as backgroundinformation ... it's done in just a few minutes.
But keep in mind, your wall thickness is not constant in your current file, scaling it into one dimension again makes it worse, not sure if that is what you want to produce then.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Alfred NESWADBA
