malhargan
306 Vistas, 2 Respuestas
my Soluti For FATAL ERROR: invalid configuration path\filename Message
Hi
I have a drawing and design lab.
After return from  summer,  IT was moved lab and Licenses servers and reinstalled programs, Everything was great except Autocad 2019.
I tried many solutions for 3 weeks, I finally discovered that problem.
 The user must be a administrator.
pendean
en respuesta a: malhargan
Only your IT can fix the issue: AutoCAD requires the first launch to be done with your login at the Administrator level, it can then be knocked back down afterwards.
malhargan
en respuesta a: pendean
Thank you.
I ran Autocad as a user and did not work.
Then I was given permission and it was too late.
So I reinstalled and it worked.
