well, FX1800 is quite old, and as you are using AutoCAD LT I guess you don't have 3D drawings and also not too big drawings. So I would suggest to disable hardware acceleration (command _GRAPHICSCONFIG) and see if the crashes get better (or worse).
Next step would be to reset settings to default, but as that would remove your customization's I would first test the graphic card/-driver before doing that step.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
