pbranford
798 Vistas, 7 Respuestas
Trimming randomly beyond intersections
Hi guys,
When trimming multiple lines the trim command goes beyond the nearest intersections, generally removing the line completely, Until recently I have never experienced this. The only change to date is a 2017 upgrade to 2020.
I've checked the edge mode and that's set to 0 and the precision set to 0.00000000. Any ideas?
j.palmeL29YX
en respuesta a: pbranford
Please post an example dwg.
BTW: I've never seen that the trim command removes a line completely  (except you choose the eRase option explicit)
Jürgen Palme
pbranford
en respuesta a: j.palmeL29YX
Attached...
j.palmeL29YX
@pbranford wrote:
Attached...
And can you tell us (or show a pic) where you what want to trim?
Jürgen Palme
GrantsPirate
EDGEMODE set to 1 will trim objects based on all objects that would cross the trimmed line if extended, set EDGEMODE  to 0.  Trim will remove a section of a pline, so if you have a box made of 4 segments of a pline and use trim on it, trim will remove the segment picked.  I use that to my advantage all the time.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
pbranford
en respuesta a: GrantsPirate
Sorry for the delay in getting back,
I've double checked edge mode and its set to 0. As this only started happening after I downloaded AutoCAD 2020, I'm wondering if there was a compatibility issue between 2017 and 2020. I'm going to start from scratch and redraw the entire drawing a fresh in 2020 with no imports from the 2017 version. This may make no difference but thought it was worth a try.
pbranford
j.palmeL29YX,
I'm going to redraw complete in 2020. I'm not sure if when I opened a AutoCAD 2017 DWG in a 2020 AutoCAD there was a compatibility issue. Failing that I may have some how corrupted the file, I hope that starting a fresh will resolve this.
j.palmeL29YX
I opened your last posted Drawing1.dwg and trimmed some lines without problems. Therefore I asked, where do you habe problems, which line you can not trim as expected.
And - a compatibiliy problem is not known for me.
Jürgen Palme
