09-16-2019
11:15 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
09-16-2019
11:15 AM
@ed57gmc wrote:
.... the linetype spec requires at least two segments, which means you have to include a small gap between them. You can't just have two continuous segments.
Not true. It may require at least two segments, but it doesn't require that any be pen-up [negative-number] ones. I have now tested that, and it works fine -- here's what I get:
[I changed the font assigned to STANDARD Style to TXT.shx the way it used to be years ago, which gives a result a lot more like the OP's original image, with the hash-marks of the same line character as the "path" part. The effect is markedly different when it's using a .ttf font as has been the default for STANDARD for a while, though it works equally well, and some may prefer the way it looks.]
Kent Cooper, AIA
