09-16-2019
10:28 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
09-16-2019
10:28 AM
In this particular case, since there is really no need for gaps in the "main" line [as one typically uses around Text elements in custom linetypes], you could simplify that to use just a single Text element, containing both backslashes together [untested]:
*AIR_SUPPLY,Air Supply
A,2,["\\",STANDARD,S=1,R=0.0,X=0.0,Y=-0.5],2
The possible drawback is that the spacing between the two in each pair will then be a function of the font definition, over which you have no control -- if you want a particular spacing, the one with two single-backslash text elements gives you that control.
Kent Cooper, AIA
