- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Thank you Blaine.
Yes. I am concerned just with the viewing. I want to save these drawings to PDF files or print them.
I was able to follow your instructions for working on the Presentations layout which I think is the Paper View.
I could add text, resize, change font and place it on the page. But I wonder if it would have been better to first create a new layer and then add the text. Would I maybe have problems like I noticed in the model space with the text not on top.
For the Model space, I found the 3D modeling ribbon.
I don't see the text in the Model space that I placed on the Paper space. I'm assuming that's what I should expect?
I'm not sure where the commands on the 3d modeling ribbon are for adding text, but I did that using MText and Move command line commands. (I found it later under the Annotate tab) I placed the text, but it is being partially hidden by the Tent rendering. Is there a way to bring it to the top?
