beyoungjr
en respuesta a: Anonymous
A 700' long pipe rack sounds pretty amazing.  Is this a rack made from pipe or a rack made for pipe?
It sounds like you recognize your Viewports, but just to be sure I'm tracking that you are playing with Viewports in a Layout (Paper Space)?
A quick trick I show my students is to double-click in the Viewport, making it active, then double-click the mouse wheel or use Zoom->Extents.  If there are more objects than you want to target for zooming then simply pre-select the target objects and type "Z" enter "O" for Zoom->Objects.  This will center your objects in the Viewport.  You can then select the Viewport scale from the drop-down list.
Then de-activate your Viewport , of course, so you do not inadvertently change the zoom scale.
The resulting display may end up bigger or smaller than you like but it will be centered and to scale.  If it doesn't fit properly then your Viewport and/or Layout is an incorrect size.
Hope this helps,
Blaine
Blaine Young
Senior Engineering Technician, US Army
