09-13-2019
11:34 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
09-13-2019
11:34 AM
Hey @ghernando
I would ask the same question put forth by @beyoungjr , is it for graphics display only? I'd assume so as opposed to more of a technical design...
I have made a screencast to illustrate this. So here is what i did:-
- I made a graphic text
- Exploded it (TXEXP) made a REGION out of it, the UNION all the contents
- I then moved the text inside the tent
- Made a surface (please bear in mind that polygon mesh is not treated as a surface in AutoCAD)
- Copied the surface with an offset from the face of the front side, then sliced the text from outside.
- Erased the remainders. (If the polygon mesh were a solid you would union it and just have the text trim from inside, but this case isnt)
- On the paper space, the orthographic view may not really work for this, so i copied the view on the lower left and generated views from it.
Hope this is a workaround or at least helps you out.
