vinodkl
en respuesta a: inflameWBW5X
Instead of using subtract, try drawing a rectangle using command " REC" of defined mesurement on the side where you want the hole and use the command "PRESSPULL" to remove the part and then delete the rectangle which would be no longer needed.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
