413 Vistas, 4 Respuestas
Viewport properties changing by itself
When opening a drawing the Viewport properties change for no reason. I've set them to "legacy hidden" and they change to "a displayed". Has anyone else discovered this issue?
vinodkl
en respuesta a: Anonymous
Have you checked this: Click here
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
en respuesta a: vinodkl
Thanks for the reply.
Not what I'm looking for.
When working in paper space I set the properties of the viewports. sometimes these properties change by themselves .
eg. properties set to "legacy hidden" and they change to "as displayed". Doesn't happen often.  Is this a bug in Autocad?
ennujozlagam
it could be? try to install latest updates from autodesk and see if helps. thanks
1. If you work in a bigger company, someone might change it.
2. I had this problem before. Dirty solution was to move everything to a new drawing.
3. If you have some pre-setup lisp routins or other "helpers" they might do it.
4. If you change to needed settings, save, close and open right away will viewport properties change?
Thanks.
