304 Vistas, 3 Respuestas
0 Suppression in Mtext Increments
Hi there,
so I've looked at many threads about 0 suppression issues and none seem to fit mine so here it is.
Using Autocad 2018, I have to create many serialized plates so I just array my first Mtext with i.e. 002900 then INC up to 003899, when I'm finished, any 0's at the begining are gone, so I add the 00 as prefixes in the INC command but then when I export my file as DXF, the two zero's are gone again.
I've tried creating a separate mtext with 00 then only one of them is kept in the end, I've also tried simple text and still the same issue.
How do I stop the 0 suppression in this case?
pendean
en respuesta a: Anonymous
INC command? No such thing in AutoCAD where you are posting, are you using an add-on?
en respuesta a: pendean
Ohhh shoot! Yeah very well might be, I just had it since the begining and it seemed pretty basic so I figured it wasn't a lisp.
I'm going to try small series typed one by one see if it works altho I wilk probably need a new addon since there are thousand of plates to serialize...
vinodkl
Try this lisp from Lee Mac for incremental number : click here
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
